PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
几题不会,求解答 [发表于 2004/10/12]
状态 开放帖 浏览量 929
6. Core planning processes have clear dependencies that require them to be performed in essentially the same order on most projects. Which of the following is the correct order as a portion of core planning processes?
A. Scope planning, scope definition, activity sequencing, activity duration estimation
B. Scope definition, scope planning, activity definition, activity sequencing, activity duration estimation
C. Scope planning, scope definition, activity sequencing, activity definition, activity duration estimation
D. Activity duration estimation, scope planning, scope definition, activity definition, activity sequencing
核心计划过程有明确的依赖关系在大多数项目中要以同样的顺序必须完成下列哪一项符合核心计划过程的正确顺序.
A. 范围规划--范围定义--活动排序--活动工期估计
B. 范围定义--范围规划--活动定义--活动排序--活动工期估计
C. 范围规划--范围定义--活动排序--活动定义--活动工期估计
D. 活动工期估计--范围规划--范围定义--活动定义--活动排序
B 核心计划过程的定义是什么?
4. A project manager estimates a project will take 14 weeks at a cost of $60,000. In signing the contract documents, the customer imposes a penalty for late completion of $2,000 per estimates that the maximum possible crashing of the project duration is 4 weeks, at an additional cost of $9,000. Assuming that the project manager is going to make the decision and that cost is the driving criteria for the project manager’s organization, what is the expected project cost?
A. $69,000
B. $71,000
C. $70,000
D. $62,000
某项目经理估算一项目要花14 周时间成本$60,000 在签合同文件时客户要求延期完工赔偿$2,000 项目工期的最大可能的赶工时间是4 周附加成本$9,000 假定成本是主要的衡量标准项目经理要作出决策什么是预期的项目成本
A. $69,000
B. $71,000
C. $70,000
D. $62,000
C 这道题有正确的计算方法吗?
楼主 美女约,不在线,有人找我吗?bigcats
发帖 19篇
注册 2004/9/25
PM币 30
经验 17点
Re:几题不会,求解答 [回复于 2004/10/12]
1 a
看看pmbok第3章的过程组的介绍,特别是那个图
2
题目好像不完整;照此描述,就不知所以能了
msn:soli_5252@hotmail.com
1楼 帅哥约,不在线,有人找我吗?5252
发帖 124篇
注册 2003/6/8
PM币 132
经验 163点
Re:几题不会,求解答 [回复于 2004/10/14]
2这时卓越PMP模拟考题的一道题,应该是要求9周完成题意才完整有正确的计算方法
不赶工的成本是60000+2000×5(延期5周) =70000
赶工的成本是60000+9000(赶工4周)+2000×1(延期1周)=71000
题意衡量项目经理标准是成本,所以要选低成本方案即不赶工70000 C
2楼 帅哥约,不在线,有人找我吗?gamebaby88
发帖 55篇
注册 2004/7/12
PM币 283
经验 64点
Re:几题不会,求解答 [回复于 2004/10/28]
1.b
definition-verification-definition-sequence-duration
3楼 帅哥约,不在线,有人找我吗?tony9602
来自 河南
发帖 101篇
注册 2003/12/24
PM币 479
经验 126点
Re:几题不会,求解答 [回复于 2004/11/4]
tony9602 在 2004-10-28 15:27:36 发表的内容
1.b
应该是 A
朱门深户视粪土,
磊落胸怀走江湖。
4楼 帅哥约,不在线,有人找我吗?zhulei
发帖 224篇
注册 2004/8/2
PM币 588
经验 225点
agree with Zhulei
5楼 帅哥约,不在线,有人找我吗?dzh
发帖 23篇
注册 2004/10/25
PM币 36
经验 12点
