fastrack [发表于 2004/10/23] 状态 开放帖 浏览量 1053 |
哪位用过rita的fastrack,感觉怎样?可不可以共享? mingli979@hotmail.com
nickle
发帖 13篇
注册 2004/8/14
PM币 137
Re:fastrack
[回复于 2004/10/23]
我先在在用,还可以,大概有两千道题吧!老金的还有国内书上的很多题都是从这出来的!300$买的,必需是原盘安装,很困难!!
fxq123
发帖 83篇
注册 2004/1/31
PM币 170
Re:fastrack
[回复于 2004/10/23]
这张盘有多少兆?能否传一些题看看。太贵,想看看题在决定是否买? mingli979@hotmail.com
nickle
发帖 13篇
注册 2004/8/14
PM币 137
Re:fastrack
[回复于 2004/10/24]
好贵
eveningstar
发帖 1689篇
注册 2004/4/7
PM币 1361
Re:fastrack
[回复于 2004/10/26]
A resource assigned to your project contacts you, trying to get off the team. He knows that an important project in his department is going to be approved and will take place at the same time as yours. He wants to work on the other project. Under the circumstances, what should you do? a.elease him from the team b.Talk to the functional manager about releasing him from the team c.Release him after he finds a suitable replacement Speak with the project sponsor about releasing him from the team ans.B
fxq123
发帖 83篇
注册 2004/1/31
PM币 170
Re:fastrack
[回复于 2004/10/26]
The project charter for a project was approved for planning, and you have just been assigned as project manager. Realizing that planning is an ongoing effort throughout the project life cycle, which processes are you MOST likely to combine? a.Scope definition and activity definition b.Activity duration estimating and schedule development c.esource planning and cost estimating d.Cost estimating and cost budgeting ans.A
fxq123
发帖 83篇
注册 2004/1/31
PM币 170
Re:fastrack
[回复于 2004/10/26]
A manager has been given responsibility for a project that has the support of senior management. From the beginning, you have disagreed with the manager as to how the project should proceed and what the deliverables should be. You and she have disagreed over many issues in the past. Your department has been tasked with providing some key tasks for the project. What should you do? a.Provide the manager with what she needs b.Inform your manager of your concerns to get her support c.Sit down with the manager at the beginning of the project and attempt to describe why you object to the project and discover a way to solve the problem d.Ask to be removed from the project ans.A
fxq123
发帖 83篇
注册 2004/1/31
PM币 170
Re:fastrack
[回复于 2004/10/26]
这两天正在作题,还有10天左右就要考试了!过后我再给大家一个结论!
fxq123
发帖 83篇
注册 2004/1/31
PM币 170
Re:fastrack
[回复于 2004/10/28]
能否给一个能使用的题目的列表!现在的题太多了
wlfch
发帖 126篇
注册 2008/9/16
PM币 99
