PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
pmp question [发表于 2004/12/17]
状态 开放帖 浏览量 627
8. The “rule of seven" as applied to statistical process control charts
means that-
应用在流程控制统计表中的 “七规则"指的是[ d or b]
a. Seven rejects typically occur per thousand inspections
每一千个检测点会产生7个不符点
b. Seven consecutive points are ascending, descending, or the same
7个问题点可向上、向下或重叠分布
c. At least seven inspectors should be in place for every thousand employees
每一千个员工就应有7个质检员
d. A process is not out of control even though seven measurements fall
outside the lower and upper control limits
尽管7个检测点都落在上、下界线控制处,但过程仍在控制中
楼主 帅哥约,不在线,有人找我吗?skyfly
发帖 21篇
注册 2004/12/13
PM币 41
经验 34点
