PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
项目综合管理的3道题 [发表于 2005/3/4]
状态 开放帖 浏览量 487
1.A project manager estimates a project will take 14 weeks at a cost of $60,000. In signing the contract documents, the customer imposes a penalty for late completion of $2,000 per estimates that the maximum possible crashing of the project duration is 4 weeks, at an additional cost of $9,000. Assuming that the project manager is going to make the decision and that cost is the driving criteria for the project manager’s organization, what is the expected project cost?
某项目经理估算一项目要花14 周时间成本$60,000 在签合同文件时客户要求延期完工赔偿$2,000 项目工期的最大可能的赶工时间是4 周附加成本$9,000 假定成本是主要的衡量标准项目经理要作出决策什么是预期的项目成本
A. $69,000 B. $71,000 C. $70,000 D. $62,000
答案是C,不知道怎么算的
2.Core planning processes have clear dependencies that require them to be performed in essentially the same order on most projects. Which of the following is the correct order as a portion of core planning processes?
A. Scope planning, scope definition, activity sequencing, activity duration estimation
B. Scope definition, scope planning, activity definition, activity sequencing, activity duration estimation
C. Scope planning, scope definition, activity sequencing, activity definition, activity duration estimation
D. Activity duration estimation, scope planning, scope definition, activity definition, activity sequencing
核心计划过程有明确的依赖关系在大多数项目中要以同样的顺序必须完成下列哪一项符合核心计划过程的正确顺序.
A. 范围规划--范围定义--活动排序--活动工期估计
B. 范围定义--范围规划--活动定义--活动排序--活动工期估计
C. 范围规划--范围定义--活动排序--活动定义--活动工期估计
D. 活动工期估计--范围规划--范围定义--活动定义--活动排序
答案是A,我觉得没一个对的。根据PMBOK中图4-1应该是“范围规划--范围定义--活动定义--活动排序/活动工期估计”
3.At which level of the Work Breakdown Struct ure is project integration management most costly to perform?
A. Level 1 B. Level 2 C. Level 3 D. Level 5
在工作分解结构的哪一层次水平项目综合管理实施代价最高
A. 水平1 B. 水平2 C. 水平3 D. 水平5
答案是D,请问WBS中层次水平是怎么分的?
楼主 帅哥约,不在线,有人找我吗?笑面虎
发帖 81篇
注册 2005/1/26
PM币 480
经验 91点
Re:项目综合管理的3道题 [回复于 2005/3/7]
好难啊,一个都没对,高手们,快来指点
1楼 美女约,不在线,有人找我吗?yuanquan
发帖 24篇
注册 2005/3/7
PM币 210
经验 43点
不知道啊!
2楼 帅哥约,不在线,有人找我吗?david505
发帖 54篇
注册 2005/2/18
PM币 247
经验 68点
1 D. 由于没有给定要求的工期目标,可以假定双方定的目标为14周。如果我是这个项目经理,就会选择既不赶工也不延期,花费成本$60,000。D与这个6万最接近,所以选它。
2 A. 直接查PMBOK, 选项B/C/D都有错误的地方。活动排序和活动工期估计虽然可以并行,A选择至少没有违背基本原则。
3 D. WBS中的最低层次是工作包,消耗的资源最多。而不是最底层的Summary Task是自动完成的,所以选D。唯一会引发争议的是“Integration Management”这个限定词。
3楼 帅哥约,不在线,有人找我吗?guolin
发帖 14篇
注册 2008/5/15
PM币 14
经验 60点
Re:项目综合管理的3道题 [回复于 2005/3/8]
有哪个高手回答一下!
4楼 帅哥约,不在线,有人找我吗?SaxonXu
发帖 118篇
注册 2005/3/5
PM币 132
经验 113点
