PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
pmp备考:人力资源题两题求解 [发表于 2005/3/10]
状态 开放帖 浏览量 539
1.At the end of a two-year project, the key stakeholders agree that the project has met all its goals and objectives outlined in the project charter and further defined in the scope and statement of work. The project is within budget and has finished on time. The management of one of the functional areas is quite upset because over half of his staff quit during the project citing long hours and lack of management support. What is the MOST correct statement about this project?
A. The project was within budget and time and achieved its objectives. Upper management is responsible for providing adequate resources, and the project manager successfully managed the project with available resources.
B.The project should be measured against how successfully it met its charter. This was not done during this project.
C.The project manager did not obtain adequate resources and did not set a realistic deadline based on resources available.
D.The functional manager is responsible for his staff and obtaining adequate resources to meet the schedule once it has been set. The project and project manager achieved all of its goals set forth in the charter.
2。You are planning a project. The functional managers will not commit any particular people to your project, because it will not begin for a few months. All of the following methods could be used to handle this situation EXCEPT?
A Use the average productivity factor for each department
B Use the average daily rate of the resources in each department times the number of resources needed of each resource type
C Use the results of the Delphi technique for the number of hours
D Use the average probability of successful completion multiplied by the number of resources needed each day
说出答案和为什么?正确答案稍后公布
楼主 帅哥约,不在线,有人找我吗?oldzzz
发帖 66篇
注册 2004/11/3
PM币 377
经验 93点
