PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
PMP题,求助高手 [econxing 修改于 2005/3/12]
状态 开放帖 浏览量 665
问题在楼下
楼主 帅哥约,不在线,有人找我吗?econxing
来自 辽宁
发帖 64篇
注册 2004/2/9
PM币 465
经验 89点
Re:PMP题,求助高手 [回复于 2005/3/12]
1. You have decided to improve your leadship capability. Then you will choose what approach?
A. to attend a PM training course
B. to improve your technical knowledge
C. to analysis PM's weakness and strength
2. About 30 percent of the team members has chosen to execute the early retirement plan option, and will be leaving the team. As a PM, what will you do first to deal with the situation?
3. You project has been initiated 3 months after schedule. You need additional resources and financial support to catch the time. You have talked several times with the sponsor on this question, but found he is not interested in it, and didn't want to solve the problem. Your project is in high risk now, what will you do?
A. to report the situation to the sponsor's boss
B. one is risk analysis and decide carry out project or termination
4. Both CPM and PERT bear the similarity that they assumes each activity duration is ......
A. is statistically independent estimates
B. is statistically dependent estimates.
1楼 帅哥约,不在线,有人找我吗?econxing
来自 辽宁
发帖 64篇
注册 2004/2/9
PM币 465
经验 89点
econxing 在 2005-3-12 10:01:56 发表的内容
朱门深户视粪土,
磊落胸怀走江湖。
2楼 帅哥约,不在线,有人找我吗?zhulei
发帖 224篇
注册 2004/8/2
PM币 588
经验 225点
1、 以下哪句话最能适合描述成本预测?
A、 拟制概率评估、不确定性、以及项目期间可能发生的通货膨胀的未来走势的过程
B、 集合并预测项目生命期间成本的过程
C、 建立可以用来评估和管理项目投资成本的预算、标准和监控系统的过程
D、 一个连续的收集、累计、分析、监控、汇报、管理成本的过程
23、 完工成本预测计算不包括:
A、 EAC=AC=(BAC-EV)
B、 EAC=BAC-CV
C、 EAC=AC=(BAC/CPI)
D、 A或B
26、 一个项目的设计估算为100000美元,在决定是否采用这个估算是时候,我们预期这个估算的正确范围应该是:
A、+10% to -15%
B、+25% to -10%
C、+10% to -5%
D、+10% to -25%
27、 在项目的执行期间,发生了大量的变更,项目经理应该如何处理?
A、 坐等所有变更公诸于众,然后印制新的进度计划
B、 进行必要的变更,但是保持进度基准计划
C、 进行必要的变更
D、 在进行任何变更前和管理层沟通
3楼 帅哥约,不在线,有人找我吗?econxing
来自 辽宁
发帖 64篇
注册 2004/2/9
PM币 465
经验 89点
朱门深户视粪土,
磊落胸怀走江湖。
4楼 帅哥约,不在线,有人找我吗?zhulei
发帖 224篇
注册 2004/8/2
PM币 588
经验 225点
