PMBOK2004的一道题,请教 [发表于 2005/12/1] 状态 开放帖 浏览量 1990 |
You are a project manager for a large consulting firm.Your superior has just asked for your input on a decision about which project your company should purse.Project A has an internal rate of return (IRR) of 12 percent.Project B has a predicted benefit cost ratio(BCR) of 1.3. Project C has an opportunity cost of U.S. $75,000. Project D has a payback period of six months.If you had to choose based on this data,which project whould you select ? A : Project A B : Project B C : Project C D : Project D C、D给的信息不全,肯定是不对的。 答案应该在A、B中,我难以选择,感觉A、B都有可能,都是赢利的项目。 标准答案是A 提示信息是这样的: The benefit cost ratio for choice B is unfavorable. 不太明白
tomduanj
发帖 63篇
注册 2004/3/13
PM币 266
Re:PMBOK2004的一道题,请教
[回复于 2005/12/4]
参考这个题目,上面的题目可能写错了 Question Statement: Based on the information provided below, which project would you recommend pursuing? Project I, with BCR (Benefit Cost ratio) of 1:1.6; Project II, with NPV of US $ 500,000; Project III, with IRR (Internal rate of return) of 15% Project IV, with opportunity cost of US $ 500,000. Choices: A. Project I B. Project III C. Either project II or IV D. Can not say from the data provided 答案很明显了
babytony
发帖 10篇
注册 2005/12/4
PM币 55
Re:PMBOK2004的一道题,请教
[回复于 2005/12/5]
D?
tomduanj
发帖 63篇
注册 2004/3/13
PM币 266
Re:PMBOK2004的一道题,请教
[回复于 2005/12/7]
顶
tomduanj
发帖 63篇
注册 2004/3/13
PM币 266
Re:PMBOK2004的一道题,请教
[回复于 2006/1/10]
的确是不懂啊
brenda
发帖 56篇
注册 2006/1/9
PM币 320
Re:PMBOK2004的一道题,请教
[回复于 2006/1/11]
对钱建立不起来概念,真是太郁闷了:(
lauramm
发帖 33篇
注册 2005/2/16
PM币 225
Re:PMBOK2004的一道题,请教
[回复于 2006/1/18]
研究一下
shengluoywb
来自 福建
发帖 50篇
注册 2005/12/26
PM币 254
Re:PMBOK2004的一道题,请教
[回复于 2006/1/23]
我认为是B,因为根据BCR的概念,项目B的毛利率为30%,在条件不太充分的前提下,只有选B了
-------------------------------------------------------------------------------------------------------- 做事,从做人开始。
ScotterZou
发帖 16篇
注册 2005/8/17
PM币 90
Re:PMBOK2004的一道题,请教
[回复于 2006/1/23]
BCR 是1.3 还是 1:3, 如果是1.3应该选B
tooj
发帖 12篇
注册 2005/12/5
PM币 165
