收到的邮件内容如下,以及在PMI网页上看到的我现在的状态,这是需要audit吗? Congratulations! Your application has been approved. Your eligibility period has begun and you have until 09 Jun 2007 (1 year)to take your examination. Please note, a percentage of candidates are randomly selected for audit after payment is remitted. For these candidates, the eligibility clock will stop and will be reset when the requirements for audit are satisfied. If you applied via the online application, please login at https://www.pmi.org/certapp/ so that you may select how you will be testing (via computer based testing or paper based testing) and remit payment. If you applied via a paper application, PMI will process payment for you. Thank you, PMI Certification Program Department 在PMI网页上看到的我现在的状态 You may now begin the scheduling process for your examination. Please note that you will not be able to schedule your examination until you have paid. Your eligibility expires on 09 Jun 2007 Start: 09 Jun 2006 End: 09 Jun 2007
