PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
圈主:lepu29341
HG信用盘0出租
圈主:de123
我被抽中审查了,审查过程中有些疑问请帮忙 [发表于 2006/7/26]
状态 开放帖 浏览量 953
上周通知审查,审核材料邮寄过去了;
收到封PMI邮件
Thank you for your interest in the PMP Credentials. Your application for the credential exam has been selected for audit. This means that you will need to provide supporting documentation for the qualifying education and/or experience that was used in your application.
On 20-May, PMI has released an upgrade to our online certification system which will grant you, the audited applicant, the ability to view the audit instructions and download the necessary forms online.
Please visit our online certification system at https://www.pmi.org/CertApp and log in using your user name and ID. If you have not yet created a user name and ID, please click on the link marked “Existing User with PMI ID”. Once logged in, please follow the online prompts to locate and read or download the audit material.
登陆PMI网站显示:You are now authorized to schedule your examination 并在下面可以下载一个文档,我看好象是关于考试注意的
请有经验的帮忙看一下,谢谢
楼主 帅哥约,不在线,有人找我吗?fly_bamboo@tom.com
注册 2006/7/20
PM币 30
经验 4点
Re:我被抽中审查了,审查过程中有些疑问请帮忙 [回复于 2006/7/26]
contact with your trainning institute
1楼 帅哥约,不在线,有人找我吗?simon_hc
发帖 32篇
注册 2005/6/24
PM币 149
经验 90点
Re:我被抽中审查了,审查过程中有些疑问请帮忙 [回复于 2006/7/27]
等他们跟你联系,会给你发一个含有你的项目经验的pdf文档,需要你填好后打印,寄回。
____________________________________
QQ:行地无疆
SHPM0310
http://spaces.msn.com/guanxiaohua/
人生没有失败,只有粉碎!
2楼 帅哥约,不在线,有人找我吗?sureman
发帖 217篇
注册 2005/6/20
PM币 995
经验 475点
