PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
几道疑难题,哪位高手能做对并讲解一下吗? [发表于 2006/8/22]
状态 开放帖 浏览量 983
1.A manager has been given responsibility for a project that has the support
from senior management. You found so many disagreement issues with the manager on what the deliverables. You department was given tasks with providing some key deliveriables for the project. What is the best solution?
A. Ask to be removed from the project
B. Provide the manager what he needs
C. Inform your manager of your concerns to get support
D. You discuss with the manager and tries to make your advice understood until you agree a solution
2. The language of contracts sometimes causes misunderstandings and creates situations that adversely affect project completion.Therefore, a relatively fast and informal method for removing the obstacles to progress should always be available. One such method is to submit the issue in question to and impartial third party for resolution. This proess is known as __
A. alternative dispute resolution(ADR)
B. problem processing
C. steering resolution
D. mediation
楼主 帅哥约,不在线,有人找我吗?pmp_longma
发帖 7篇
注册 2006/8/22
PM币 70
经验 12点
Re:几道疑难题,哪位高手能做对并讲解一下吗? [回复于 2006/8/22]
3. Which of the following is an example of 'applicable term' negotiation?
A. After buyer's receipt of seller's invoice, within how many days shall the buyer make a payment to the seller?
B. Who is the seller that has many branches in China and overseas countries?
C. What are the seller's responsibilities?
D. What actions shall either party take at the time of force majeure events occur?
4. Which of the followings is not proper for the explanation of procurement document package?
A. It is prepared by the potential seller or the nominated bidder as a result of request seller responses process.
B. It is the basis on which a seller prepares a bid
C. It is the basis for documentation of procurement documents
D. It is often called as contract 'statement of work(SOW)'
5. High-risk projects are always of concern to senior management and will receive the most scrutiny. The major concern of the project manager of a high-risk project is the the tendency for senior managment to often__
A. interrupt or intervene in the project's potential risk
B. avoid or deny the project's pontential risk
C. give low priority to reource allocation
D. give support to the project when additional resources are requested
Answer:
1. B 2.A 3.B 4.B 5.A
1楼 帅哥约,不在线,有人找我吗?pmp_longma
发帖 7篇
注册 2006/8/22
PM币 70
经验 12点
1. A.这是逃避责任,消极的做法。C. 就算是获得你部门经理的支持也未必能解决问题。D.因为the manager才是授权的项目负责人,他/她对项目的所有 deliverables 负责,所以解决方法并不是非得得到你的同意。因此只有B,按照项目负责人要求的去做。
2楼 美女约,不在线,有人找我吗?heidy
发帖 85篇
注册 2006/7/7
PM币 448
经验 131点
Re:几道疑难题,哪位高手能做对并讲解一下吗? [heidy 修改于 2006/8/22]
4.这道题一定是弄错了, 问号前面少了个except 吧.Procurement document package 正是为潜在卖家投标而准备的。A.由潜在卖家准备的说法是错误的。D.它包括contract sow,但还有其他,比如评标方法等。
3楼 美女约,不在线,有人找我吗?heidy
发帖 85篇
注册 2006/7/7
PM币 448
经验 131点
