PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
PMP question [发表于 2007/11/14]
状态 开放帖 浏览量 970
Q1) I received a membership confirm mail in early of Nov, is there any membership certificate set to me?
Q2) In case I certify the PMP, will my PMP member ID the same as my PMP member ID?
Q3)In case I take the exam and certify the PMP in Nov 2007, will I be certified from Nov 2007 to 31 Dec 2010?
Similarly, in case I take the exam and certify PMP in Jan 2008, will I be certified from Jan 2008 to 31 Dec 2011?
楼主 帅哥约,不在线,有人找我吗?sosam
来自 香港
注册 2007/7/1
PM币 55
经验 16点
Re:PMP question [pmp2002 修改于 2007/11/15]
Q1)sure,you will receive the membership certificate later.
Q2)In case U certify the PMP, your PMI member ID is not the same as your PMP certificate ID
Q3)In case U take the exam and certify the PMP in Nov 2007, U will be certified from the date to 31 Dec 2010
in case U take the exam and certify PMP in Jan 2008, U will be certified from the date to 30 June 2011
1楼 帅哥约,不在线,有人找我吗?PMP2002
发帖 3424篇
PM币 43
经验 7462点
Re:PMP question [回复于 2007/11/15]
pmp2002 在 2007-11-14 11:47:54 发表的内容
Q2)In case U certif
Q3)
Ans
In case U take the exam and certify the PMP in Nov 2007, U will be certified from Jan. 2008 to 31 Dec 2010
in case U take the exam and certify PMP in Jan 2008, U will be certified from July2008 to 30 June 2011?
For the Question 3, I don't understand it. Referring to your above anwser, it seems that not make sense that I am not a certify PMP in Dec 2007 in case 1. Also it seems that not make sense that I am not a certify PMP in Feb 08 ~Jun 08 in case 2.
Is that any cerify PMP personnel who passed the exam in Quarter 1 / 2 here? Can you check your certificate to help me answer my question.
Thais is because I want to make decision when should Itake the exam.
Thanks
2楼 帅哥约,不在线,有人找我吗?sosam
来自 香港
注册 2007/7/1
PM币 55
经验 16点
U mail to PMI to get the answer.
3楼 帅哥约,不在线,有人找我吗?PMP2002
发帖 3424篇
PM币 43
经验 7462点
