PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
项目选择方法解惑 [ruhe_PMP 修改于 2008/7/31]
状态 开放帖 浏览量 804
[Question]: I know that Project Selection Methods of two types are Benefit Measurement Methods and Constrained Optimization Methods.
Just want to know that Economic Value Add (EVA), IRR, NPV, Payback Period, PV and NPV are coming into which type ?
All above involve calculation. Are they coming under constrained optimization methods?
If yes, why does benefit to cost ratio come under benefit measurement methods?
[Answer]:
The Project selection methods IRR, NPV, Payback period, PV come under Benefit Measurement Methods, also known as Comparative approach and these are Cash Flow Analysis Techniques. It is not correct to think that just because these methods involve calculations, they fall under Mathematical Approach.
Examples of Mathematical approach (also known as Constrained optimization method) are: Linear Programming, Integer Programming, Dynamic Programming, Multi Objective Programming, and these methods use programming in the form of algorithms to arrive at the Project Selection. Its easier if you remember that Mathematical Approach involves complex mathematics and requires the use of a computer.
楼主 美女约,不在线,有人找我吗?ruhe_PMP
发帖 50篇
注册 2008/5/30
经验 108点
