需求工程网址集锦(发表者:流水的光阴) [发表于 2003/2/19]
状态 开放帖 浏览量 8254
* 帖子主题 * 需求工程网址集锦 你是第 374 位浏览者
流水的光阴
军衔: PMU初级一星
财产:
经验:
魅力:
来自: 深圳市
鉴定: 本功能已经被关闭
发帖: 119篇
注册: 2002-6-27
下面是一些有关需求工程的网址,希望大家能从中找到些许帮助,也希望大家多多关注本版块,它的发展离不开您的努力,谢谢!
Requirements Engineering Resources
http://www-comp.mpce.mq.edu.au/~didar/seweb/resources.html
Knowledge Acquisition and Sharing for Requirements Engineering (KARE)
http://www.kare.org/
Index of Requirement Engineering
http://www.ccs.neu.edu/research/demeter/related-work/requirement-engineering/
A Proposal for Requirement Engineering
http://www.science.mii.lt/ADBIS/local2/negoro.pdf
Trends of Requirement Engineering
http://www.ipsj.or.jp/members/Magazine/Eng/2006/article005.html
Reusing Scenario Based Approaches in Requirement Engineering Methods: CREWS Method Base
http://cui.unige.ch/~ralyte/publications/REP99.pdf
V-Model and Requirement Engineering
http://cafe.rational.com/HyperNews/get/hn/rosecafe/2817/2.html?nogifs
Requirement Engineering for Software Performance
http://www.ifi.uib.no/projects/raisa/publications/abstracts/ifi-44.html
Requirement Engineering - Customer-Oriented
http://www.cs.ualberta.ca/~sorenson/cmput401/lectures/RequirementEng/sld001.htm
Intelligent Requirement Engineering
http://www.cs.tamu.edu/research/CFL/projects/intreq.html
Requirement Engineer Organization
http://www.sbdi-consulting.com/feb2001.shtml
Formal Requirement modeling Languages
http://www.cs.toronto.edu/~gross/istar/references02-44.htm
RE modeling for Business Goals and Rationales behind IT development
http://www.cs.toronto.edu/~gross/istar/references02-46.htm
Enterprise Modeling Framework
http://www.cs.toronto.edu/~gross/istar/references02-48.htm
Systematic Development of Requirements From Higher-Level Goals
Capturing the Requirements
http://www.cs.umd.edu/~sharip/swebook/requirement.html
Software Requirement Analysis
http://www.comp.hkbu.edu.hk/~pfsum/sci4040/node13.html
Requirement Analysis Techniques
http://www.cse.unl.edu/~scotth/courses/461-fall98/week7/tsld021.htm
http://www.chekyang.com/se203/chap2.htm
http://www.cs.chalmers.se/Stat/Bioinfo/Master/HCI2001/L2_Reqs.htm
The Art of Requirement Analysis
http://www.eng.uwaterloo.ca/~msci738/student_work/x5liang.html
Process-Oriented Requirement Analysis Supporting the Data Warehouse
Design Process
http://www.ifs.tuwien.ac.at/ifs/general_information/people/tjoa/pub_others/lis_dexa00.doc
Scenario Based Requirement Analysis (1998)
Method Enhancement with Scenario-Based Techniques
http://citeseer.nj.nec.com/278758.html
Supporting Scenario-Based Requirement Engineering
http://citeseer.nj.nec.com/sutcliffe98supporting.html
CREWS-SAVRE: Scenarios for Acquiring and Validating Requirements
http://citeseer.nj.nec.com/maiden98crewssavre.html
Human Errors and System Requirements
http://citeseer.nj.nec.com/sutcliffe99human.html
Scenario-Based Techniques for Supporting the Elaboration and the Validation of Formal Requirements
http://citeseer.nj.nec.com/224561.html
Requirements Elicitation and Validation with Real World Scenes
http://citeseer.nj.nec.com/haumer98requirement.html
Guiding The Construction Of Textual Use Case Specifications
http://citeseer.nj.nec.com/rolland98guiding.html
Inquiry-Based Requirements Analysis
http://citeseer.nj.nec.com/context/98828/0
Requirements Engineering - A Good Practice Guide (Book) 1997
http://citeseer.nj.nec.com/context/272826/0
Software Requirements and Specifications (Book) 1995
http://citeseer.nj.nec.com/context/96173/0
Deriving Goals from a Use Case Based Requirements Specification for an Electronic Commerce System
http://citeseer.nj.nec.com/antn00deriving.html
Structuring Use Cases with Goals
http://citeseer.nj.nec.com/context/562009/0
CORE - a method for controlled requirements expression
http://citeseer.nj.nec.com/context/164131/0
A Co-operative Scenario-Based Approach to Acquisition and Validation of System Requirements : How Exceptions Can Help!
http://citeseer.nj.nec.com/maiden97cooperative.html
An evaluation of inquiry based requirements analysis for an Internet service
http://citeseer.nj.nec.com/context/598996/0
Requirement Analysis Bibliography
http://ivs.cs.uni-magdeburg.de/sw-eng/us/bibliography/bib_16.shtml
Petri Net Approaches for Requirement Analysis
http://www.informatik.uni-hamburg.de/TGI/pnbib/a/anneberg_l3.html
Business Systems Requirements Analysis (BSRA)
Analyzing Business Processes and Defining Business Systems Requirements
http://www.perfdev.com/bsra.htm
The Records Requirements Analysis and Implementation Tool (RRAIT)
http://www.ctg.albany.edu/projects/er/rrait.html
Requirement Elicitation Questionaire
http://phoenixsun.trentu.ca/~skennedy/Question.pdf
http://facstaff.bloomu.edu/cjones/classes/Software%20Engineering/Notes/Requirement%20Elicitation.doc
软件需求资料下载
http://www.seforum.net/dl_rqmnt.htm
Requirement Analysis: Context, Approach, and Users
http://www.eucybervote.org/fr/Reports/KISTA-WP2-D4V3-v1.0-01.htm
http://www.ncst.ernet.in/~sefac/slides/Analysis_Concepts.ppt
Enable Involving End-Users in Requirement Elicitation
http://www.infj.ulst.ac.uk/~cbcj23/uudmig/jinzhi.ppt
Requirements Support
http://www.cs.vu.nl/vakgroepen/ai/projects/req/
Requirement Engineering: A Road Map
JPREview Tool and Method for Requirement Engineering
http://www.comp.lancs.ac.uk/computing/users/cosh/Jpreview.pdf
Requirements Management Plan
http://www.cis.umassd.edu/~u_mabdulhadi/vvm/SRMplan.doc
Eliciting and Analyzing Requirements
http://softwarestudio.org/classes/lectures/RequirementsElicitation.pdf
Software Architectures Architecture Requirements
http://www.telecom.lth.se/Personal/johannod/pub/architecture/architecture_requirements.html
From Sequence Diagrams to Behavior Models
http://www.doc.ic.ac.uk/~su2/pubs/WUTML.pdf
Goal-Directed Concept Acquisition in Requirements Elicitation
http://citeseer.nj.nec.com/context/93643/0
Requirements Determination - Eliciting Requirements
http://www.cs.strath.ac.uk/teaching/ug/classes/52.234/Requirements_Determination_2.pdf
A Requirement Management Database System for Product Definition
http://www.mcb.co.uk/pdfs/forums/06810cc2.pdf
A Method for Evaluation of Performance of Requirements Inspection
http://www.escom.co.uk/conference2000/kantoriwitz.pdf
Volere Requirements Specification Template
http://www.systemsguild.com/GuildSite/Robs/Template.html
Requirement Specification Template
http://cafe.rational.com/HyperNews/get/hn/umlcafe/920/1.html?nogifs
Requirement Specification - Suggested Formats
http://www.icis.ntu.edu.sg:8000/student_info/doc/Requirement-Model-Format.PDF
A Methodological Approach to Requirement Specification of Embedded Systems
http://www.computer.org/proceedings/icfem/8002/80020183abs.htm
Software Requirement Specification (Glossary)
http://www.chambers.com.au/glossary/SRS.htm
Independent Verification and Validation (IV&V)
http://www.ivv.nasa.gov/iso9000/isodocs/IVV_09-1.pdf
Information System Verification and Validation During Requirement Analysis Using Petri Nets
http://www.informatik.uni-hamburg.de/TGI/pnbib/s/sakthivel_s1.html
A Validation Toolset for UML
http://www.eecs.umich.edu/~wwshen/tool/tool.html
FDA Regulations and Software Process Documentation
http://www.spc.ca/downloads/products/eset/ee/ee_and_fda.pdf
Requirement Allocation Matrix and Traceability Matrix
http://ltpwww.gsfc.nasa.gov/IAS/pdfs/traceability_matrix.pdf
Requirements Management Technology Overview
http://www.incose.org/tools/reqsmgmt.html
A Comprehensive Traceability Model to Support the Design of Interactive Systems
http://math.uma.pt/wisdom99/papers/castro/CastroToranzo.html
Traceability Diagram and Mapped Requirement Diagram
http://www.tbi.com/caliberrm30/tdmrd.html
ESA/ESTEC/WME Traceability: a high added value
http://www.estec.esa.nl/wmwww/WME/essde/tools/tools007.htm
Traceability
http://www.mfcomputers.com/trace.htm
Traceability Management with UML Through Goal-Oriented Objects
http://www.omg.org/docs/ad/99-11-02.pdf
Reqs Traceability
http://www.hoora.org/HOORAProcess/RequirementsTraceability.htm
Requirements Tracing - An Overview
http://www.sei.cmu.edu/str/descriptions/reqtracing_body.html
Software Requirements (Book) 1999
http://www.microsoft.com/mspress/books/toc/3215.asp
Requirements Management and Project Planning Made Easy
http://www.omni-vista.com/
Requirements Management Place
http://www.rmplace.org/
Requirements Bibliography
http://www.rmplace.org/Bibliography/index.htm
Combining Software Requirements Specifications with Use-Case Modeling
http://www.spc.ca/downloads/srs_usecase.doc
Customer Rights and Responsibilities
http://www.processimpact.com/articles/customer.html
First Things First: Prioritizing Requirements
http://www.processimpact.com/articles/prioritizing.html
In search of Excellent Requirements
http://www.processimpact.com/articles/exc_reqs.html
10 Requirements Traps to Avoid
http://www.processimpact.com/articles/reqtraps.html
Listening To the Customer's Voice
http://www.processimpact.com/articles/usecase.html
Writing Quality Requirements
http://www.processimpact.com/articles/qualreqs.html
Who Makes the Requirements Decisions
http://www.spc.ca/essentials/aug2300.htm#3
Apply Equal Rigour to Requirements Gathering and Change Management
http://www.spc.ca/essentials/aug2300.htm#1
Understanding Your Stakeholders
http://www.spc.ca/essentials/aug2300.htm#2
Automating Requirements Management
http://www.processimpact.com/articles/rm_tools.html
Requirement Engineering (RE) Hotlists
http://www.cc.gatech.edu/computing/SW_Eng/hotlist.html#requirements
Software Prototyping and Requirements Engineering
http://www.dacs.dtic.mil/techs/abstracts/spare.html
http://www.dacs.dtic.mil/techs/prototype/title.shtml
Rapid Evolutionary Development: Requirements, Prototyping & Software Creation
http://www.wiley.com/Corporate/Website/Objects/Products/0,9049,65716,00.html
Prototyping In Software Development Cycle
http://www.firelily.com/opinions/cycle.html
Software Requirements Engineering 2nd Ed. (Book) 1988
http://www.computer.org/cspress/catalog/bp07738/toc.htm
Just Enough Software Requirements
Eliciting, documenting, and managing software requirements for Internet-time projects
http://www.yourdon.com/seminars/RM.HTML
REQUIREMENT CAPTURING THROUGH ANIMATION AND MMI PROTOTYPING
http://www.esi.es/ESSI/Reports/All/10497/
Prototyping and Software Development Approaches
http://www.is.cityu.edu.hk/Research/Publication/paper/9704.pdf
Tutorial: Functional Specification What and Why
http://www.mojofat.com/tutorial/
http://whatis.techtarget.com/definition/0,,sid9_gci212169,00.html
http://www.pcwebopedia.com/TERM/F/functional_specification.html
Functional Specifcation and Review
http://www.epri.com/eprisoftware/processguide/funcspec.html
Template Functional Specification
http://www.coe.neu.edu/~yeracar/mim3132/func_spec_temp.html
The Requirement and Design Specification Language SPECTRUM
http://www4.informatik.tu-muenchen.de/proj/korso/papers/v10.html
Temporal-Logic vs. Statecharts as a Specification Language
http://www.time-rover.com/statchrt.html
Requirement Specification in Pseudo-Natural Language in PROMIS
http://www.computer.org/proceedings/compsac/7119/71190096abs.htm
A Specification Pattern System
http://www.cis.ksu.edu/santos/spec-patterns/
Software Requirement Specification in Controled Natural Language and its Analysis
http://www.ipsj.or.jp/members/SIGNotes/Eng/09/1993/095/article003.html
Automated Quality Analysis Of Natural Language Requirement Specifications
http://satc.gsfc.nasa.gov/support/PNSQC_OCT96/pnq.html
From Object-Process Diagram to A Natural Object-Process Language
http://smi-web.stanford.edu/people/peleg/new_OPLshort.pdf
Advanced Requirements Specification
http://www.spipartners.nl/data/train_course_gilbreqs_en.html
Message Sequence Chart (MSC)
http://www.etsi.org/ptcc/ptccmsc.htm
Requirement Document Template
http://www.cc.gatech.edu/computing/classes/cs3302_96_winter/projects/requirements.html
Software Requirements Specification Document Template
http://www2.ics.hawaii.edu/~johnson/413/lectures/5.2.html
Functional vs Non-Functional Requirements
http://lists.ebxml.org/archives/ebxml-requirements/199912/msg00008.html
Representing and Using Non-Functional Requirements: A Process Oriented Approach
http://citeseer.nj.nec.com/mylopoulos92representing.html
http://www.cs.odu.edu/~zeil/cs451/Lectures/02reqts/definition/definition_htse3.html
How Fast Is Fast - Using Non-Functional Requirements to Test Requirement Quality
http://ftp.starbase.com/pdf/How_Fast_Is_Fast.pdf
An Approach to Quantitative Non-Functional Requirements in Software Development
http://www.geia.org/Wkshp2000/Dallas/seswpapers/02PAPER.PDF
Defining Non-Functional Requirements
http://www.bredemeyer.com/pdf_files/NonFunctReq.PDF
Z01 Requirement Analysis
http://www.cs.ucl.ac.uk/staff/C.Mascolo/teaching/Z01/Z01-req.pdf
Correlate In a Nutshell AOP - An Aspect Language for Non-Functional Requirements
http://www.cs.kuleuven.ac.be/~distrinet/projects/CORRELATE/introduction.html
Requirements, Analysis, Specification, and Design Tools
http://www.methods-tools.com/tools/analdes.html
Larch: Languages and Tools for Formal Specifications
http://www-theory.dcs.st-and.ac.uk/~mnd/larch.html
Algebraic Specification Techniques and Tools for Software Development: The ACT Approach (Book) 1993
http://www.wspc.com/books/compsci/1877.html
Just Enough Structured Analysis (Book) 2001
http://www.yourdon.com/books/msa2e/
Structured A & D
http://www.popkin.com/products/sa2001/struct/structured.htm
Structured Analysis & Design
http://www.excelsoftware.com/sasd.html
Value of Information Structured Analysis of Risk Tool
http://www.nsa.gov/programs/tech/factshts/risktool.html
Structured Analysis: Defining the Problem
http://www.nmt.edu/~shipman/soft/demarco.html
Business Structured Analysis and Design 5 Days Workshop
http://www.construx.com/seminars/onsite/topic-struc_anal.htm
How to Integrate Object Orientation with Structured Analysis & Design
http://www.computer.org/software/so1989/s2074abs.htm
Structured Analysis/Design Methodologies & HIPAA
http://www.linuxmednews.com/linuxmednews/991683724/index_html
Postmodern Structured Analysis (PSA)
http://wwwhome.cs.utwente.nl/~roelw/OIS/chapter20-handout.pdf
The Toolbridge: Structured Analysis with case/4/0 and Object-Oriented Development with objectiF
http://www.microtool.de/case40/en/sp_320_toolbridge.htm
Standards for Structured Analysis Representations
http://www.uta.edu/cse/levine/cs3310/sastandards.html
Using Structured Analysis with Object Based Design Methods
http://www.jr-and-assoc.demon.co.uk/saob_des.htm
IDEF0 Overview Function Modeling Method
http://www.idef.com/idef0.html
There Are Other Structured Analysis Techniques
http://www.csulb.edu/colleges/coe/ae/ae484/str_ana/
Software Requirements Engineering for Practitioners
http://www.sei.cmu.edu/products/videos/sw.req.eng.for.prac.html
SA/RT Structured Analysis with Real-Time Extension
http://dce.felk.cvut.cz/cak/Publikace/2000/00wasz_SART.pdf
Real-Time Structured Analysis (RTSA)
http://www.instantweb.com/foldoc/foldoc.cgi?RTSA
A Unifying Framework for Structured Analysis & Design Models
http://uk.cambridge.org/computerscience/theoretical/catalogue/0521391962/default.htm
IDEF/SADT Related Documents
http://www.uwp.edu/academic/mis/baldwin/idef.htm
From SADT to A Formal OO-RML
http://www.utdallas.edu/~chung/RE/7FR.SR.pdf
SADT Basic Concepts
http://www.tni.fr/tni/offre/orchis/orchis.detail.technique.eng.html#conc
An SADT Model
http://panoramix.univ-paris1.fr/CRINFO/dmrg/MEE97/misop001/opg25.html
Formal and Semiformal Methods for Capturing Requirements
http://www.cs.utexas.edu/users/almstrum/cs373/general/SRS-methods.html
Petri Nets
http://everest.ento.vt.edu/~sharov/PopEcol/lec1/petrinet.html
Axiomatic Specification of ADT
http://www.cs.unc.edu/~stotts/204/ADTs/
ER Modeling
http://www.umich.edu/~cisdept/bba/320/1999/fall/er-modeling/
CSP (Communicating Sequential Processes)
http://www.afm.sbu.ac.uk/csp/
PSL/PSA (Problem Statement Language/Problem Statement Analyzer): A Computer Aided Technique for Structured Documentation and Analysis of Information Processing Systems
http://citeseer.nj.nec.com/context/978305/0
SREM (Software Requirements Engineering Methodology)
http://citeseer.nj.nec.com/context/115656/0
Advantages of Stimulus Response Requirement Specification Techniques for System Testing
http://www.cs.ubc.ca/formalWARE/abstracts/incose3.pdf
Capturing The Requirements
http://joda.cis.temple.edu/~wolfgang/c338f99/SWE04/SWE04.PDF
Information On VDM (Vienna Development Method)
http://www.csr.ncl.ac.uk/vdm/
ISO VDM Specification Language VDM-SL
http://www.csr.ncl.ac.uk/vdm/#standard
Automatic Testing Data Generation from VDM-SL Specifications
http://home.in.tum.de/atterer/uni/sep/
GIST (Generating InStructional Text)
http://ecate.itc.it:1024/projects/gist.html
GIST Bibliography
http://ecate.itc.it:1024/projects/gist/gist-bibliography.html
Requirements Process Improvement Through Phased Introduction of Good Practices
http://www.comp.lancs.ac.uk/computing/research/cseg/projects/reaims/papers/SPIPpaper.pdf
Impact Analysis Checklist for Requirements Changes
http://www.processimpact.com/process_assets/impact_analysis.doc
三分做事,七分做人。
[ 该贴在 2002年7月3日 21:45:12 被 流水的光阴 修改过 ]
楼主 美女约,不在线,有人找我吗?aurora
发帖 777篇
PM币 3095
经验 180点
