About EVM? please comment [发表于 2004/2/7]
状态 开放帖 浏览量 1575
I offer following calculation for comments. To see
if my understanding of EVM is correct.
EV calculation example:
1. Suppose one software programmer is given a module task.
The plan for the task is one programmer working one week(five days per week, 8 hours per day).
so PV for this module task should be 40Man*Hour.
if the actual work result shows that:
by the end of the week, only 80% work is done.
then the AC is 40MH, EV is 32MH.
CV=EV-AC=-8MH
SV=EV-PV=-8MH
CPI=EV/AC=80%
SPI==EV/PV=80%
Is the above calculation correct?
Hope some gurus give me judgement!
Thanks ahead!
楼主 帅哥约,不在线,有人找我吗?kantata
来自 四川
发帖 18篇
注册 2004/2/7
PM币 85
经验 20点
Re:About EVM? please comment [回复于 2004/2/8]
我以前的一个贴子 :)
http://www.mypm.net/bbs/article.asp?titleid=11081&ntypeid=24
****有问题,找IT项目管理****...
1楼 帅哥约,不在线,有人找我吗?camer
发帖 2745篇
注册 2003/3/3
PM币 14759
经验 5438点
Re:About EVM? please comment [回复于 2004/2/19]
You'd better clarify some concepts.
In ur case, BCWS = 40MH (Suppose the rate of the programmer is 1)
BCWP = 32MH ACWP = 32MH
SV=BCWP-BCWS=-8MH CV=BCWP-ACWP=0
So, your work is behind the schedule but there is no a budget overrun.
SPI = BCWP/BCWS = 0.8, CPI = BCWP/ACWP =1
Your caculation is wrong.
MSc.MoP MPMI
务外非君子
守中是丈夫
2楼 帅哥约,不在线,有人找我吗?BenLomond
发帖 48篇
注册 2004/2/19
PM币 95
经验 107点
BTW, BCWS = Budgeted Cost of Work Scheduled
BCWP = Budgeted Cost of Work Performed
ACWP = Actual Cost of Work Performed
MSc.MoP MPMI
务外非君子
守中是丈夫
3楼 帅哥约,不在线,有人找我吗?BenLomond
发帖 48篇
注册 2004/2/19
PM币 95
经验 107点
